Smooth Torquer
posted on 19/4/04 at 12:33 PM |
Reverse gearbox (again)
Hi all,
Im sure that this has been discussed before, but now that BEC are becoming more commanly built i was wondering which reverse box solution people had
found worked best?
Thanks in advance
Sam
ChrisGamlin
| posted on 19/4/04 at 02:22 PM |
You might want to have a hunt via search, as Im sure there have been a few lengthy threads on them before.
Basically though, for a Locost type car you have 3 choices
1, Mechanical reverse box situated in the middle of the prop
2, Electric version which either drives a gear off the sprocket or off the diff at the back
3, SWMBO power (aka the helpful passenger pushing technique)
Option 1 is more widely used but most designs seem to be weak. Some people get away without any problems, but Id say the failure rate is too high
considering the investment required.
Option 2 is used when reverse is a necessity (racing for example), but you dont want the single point of (some would say likely) failure. An electric
reverse isnt as powerful as a mechanical one, and you need to put up with a car sounding like a milkfloat in reverse, but the benefits are that you
dont get the additional vibration etc usually associated with having a mech reverse box in the middle of the transmission tunnel.
Personally Ive opted for option 3, in 2 years of track days and driving on the road (approx 2-3k a year on road) I can only recall once where I really
wished I had reverse. On some other occasions I guess it would have been nice, but rolling the car around is really easy so its no hardship and a
small price to pay for a more reliable (and cheaper) drivetrain.
HTH
Chris
Smooth Torquer
| posted on 19/4/04 at 04:43 PM |
HEHEHE Option 3 sounds good to me
I dont really like the idea of having a weak point in my transmition just to backwards occationally
I'll do some more searching and see what i can find
Thanks very much
Sam
Lightning
| posted on 19/4/04 at 10:59 PM |
I was considering cutting the floor out of the passangers side and having an inducator light on the dash saying REVERSE. When lit the passanger pushes
back on the ground with her feet AKA Flintstone style.
Should work
thekafer
| posted on 19/4/04 at 11:23 PM |
...... with her feet......
I suspect you'll experience a severe whinning sound.........It's brilliant!!!
Fletch.
I'd rather have a bottle in front of me than a frontal labotomy...
