Author: Subject: Quick engine question...
locostbuyer83
posted on 5/1/10 at 02:07 PM Reply With Quote
Hi Everyone. I know this will probably have been covered but i've been reading for about an hour so far and still not sure..
I've got to the point of my build where i need to buy my engine.
The plan was to go for an R1 but then i heard about the ZX12R engine which i thought would be better, as in faster and more torque.
Then i found out you need a dry sump which puts the engine way over budget.
But i've just read that someone had a ZX12R with a baffled wet sump (source: http://www.locostbuilders.co.uk/viewthread.php?tid=35278&page=2)
I'm planning on road use only really but i can't afford to spend more than 2k on my engine.
Should i just stick with the R1 plan?
What if i change engines once the car is registered on the road is it a long procudure to register the new engine? Thinking buy the cheaper R1 now and upgrade later?
Thanks in advance guys!!
TimC
posted on 5/1/10 at 02:10 PM Reply With Quote
The ZX12R does not need a dry sump! Installation costs are now quite similar for the two engines that you quote, and if you're careful the ZX12R can be the bargain motor.
Don't forget to budget for a Powercommander, Exhaust, Air Filter etc etc. Check out Hellfire's build site for details.
Miks15
posted on 5/1/10 at 02:11 PM Reply With Quote
sorry cant help with engine choice as ive never had any BEC
but im pretty sure you just need to tell tyhe DVLA the new engine capacity and number in the V5 if you change engine
locostbuyer83
posted on 5/1/10 at 02:30 PM Reply With Quote
Oh right thanks!
just looking at Hellfire's build site.. just what i needed!
fesycresy
posted on 5/1/10 at 03:19 PM Reply With Quote
I had an R1.
I would buy a ZX12 now though, as Tim said there are a few bargains around.
Or you could save your pennies and buy a ZX14
locostbuyer83
posted on 5/1/10 at 03:28 PM Reply With Quote
Originally posted by fesycresy
I had an R1.
Think i'll go for the ZX12.
Is there anyone in sussex thats already done one of these? I'm keen to get on with my build as i'd like it done by the summer but my to do list is huge and seems never ending
posted on 5/1/10 at 03:35 PM Reply With Quote
ZX12R is a great choice of engine IMHO. If you need any help or advice just drop us a U2U and we'll help if we can.
Phil
eznfrank
posted on 5/1/10 at 03:42 PM Reply With Quote
I also have an Indy ZX12 with a baffled sump as recommended by a number of people who've successfully run one without dry sump.
locostbuyer83
posted on 5/1/10 at 03:49 PM Reply With Quote
My GF's dad owns an engineering company so i should be able to get bits done cheap enough. Whats envolved with adding baffles to the sump, have you got any photos?
eznfrank
posted on 6/1/10 at 09:11 AM Reply With Quote
I had mine done my Martin Keenan but basically he just chopped about 2-3 inch off the bottom and then boxed it out so it retained roughly the same volume overall, the sump plug is also moved to the side. The baffle is actually what was the old side wall with a couple of V's cut in the bottom.
The pickup also need modifying but they're only plastic so you can just cut it to size with a hacksaw and then again put a V or two in the bottom.
Some have a horizontal baffle also. No pics I'm afraid but there is one of someone else's here...
http://www.locostbuilders.co.uk/viewthread.php?tid=116663
and more here....
http://www.locostbuilders.co.uk/viewthread.php?tid=40225
[Edited on 6/1/10 by eznfrank]
