Poll: dynojet quick shift vs trickshift [View Results]
dynoject quickshift
trickshift - up only
trickshift - up and down
Author: Subject: dynojet quick shift vs trickshift
dan__wright
posted on 14/1/10 at 12:35 PM Reply With Quote
which one do i go for?
dynoject quickshift
i like this as its only 1 additional components, plugs into the pciii so no wiring, only 1 extra wire, nothing extra to mount anywhere, digital adjustment on the pciii - cheap
trickhifter up only
as far as i can see doesn't do anything more / better than the dynojet one, is mor expensive and more wires / boxes / wiring needs doing
trickshifter up + down
can do down shifts too but is it worth it? more expensive and even more bits to have to find homes for.
FREE THE ROADSTER ONE…!!
maximill666
posted on 14/1/10 at 12:52 PM Reply With Quote
The Dyojet quickshifter must also be used with the dynojet ignition module otherwise it wont work, which bumps the price up quite a bit as its virtually the same price as the PC3 unit itself
dan__wright
posted on 14/1/10 at 01:03 PM Reply With Quote
afaik it can do it either on fuel or ignition if you have the ign module.
maximill666
posted on 14/1/10 at 01:08 PM Reply With Quote
It will only work with the igniton module connected to the PC3, without it wont do anything, I have previously tried it.
Breaker
posted on 14/1/10 at 02:17 PM Reply With Quote
I don't understand why the quickshifter is so expensive. What's inside the sensor: a spring and some kind of microswitch ?
[Edited on 14/1/10 by Breaker]
