bowood14
| posted on 24/1/10 at 03:05 PM |
Hesitant fireblade
Here goes with the problem Car (MK Indy 919 Fireblade) was running fine. Then the rectifier started smoking, got really hot, so replaced it and the
battery. Since then havent used it for a while. So went for drive over Christmas and it was hesitant when giving it some, runs fine low down. Today :
Changed plugs, checked earths, took air box off as I had changed air filter as well. Cant find any problems and still wont go properly.
So what else should I check could the rectifier done some other damage?
MakeEverything
| posted on 24/1/10 at 03:15 PM |
HT Leads / Leads from the rectifier?
Kindest Regards,
Richard.
Dangle_kt
| posted on 24/1/10 at 03:49 PM |
did you drain the carbs? They could have gummed up if stored for a long time?
bowood14
| posted on 24/1/10 at 03:56 PM |
It wasnt left that long only 3-4 weeks at most so dont think carbs are problem. It seems to be too much of a coincedence that its started running
poorly after rectifier burn out.
I dont know what other damage the rectifier could have caused?
ReMan
| posted on 24/1/10 at 05:07 PM |
I believe (from reading, not personal experience) that your symptom can be caused by a faulty rectifier, is your replacement known good?
[Edited on 24/1/10 by ReMan]
bowood14
| posted on 24/1/10 at 06:11 PM |
It was new so would hope is ok BUT may test if no one comes up with any better ideas Thanks
Steve Hignett
| posted on 24/1/10 at 08:39 PM |
You need to discount the Reg/Rec asap really as it could easily be the carbs that are dirty...
mad-butcher
| posted on 25/1/10 at 11:41 AM |
Carbs
tony
bowood14
| posted on 25/1/10 at 01:39 PM |
Thanks for replies I have checked rectifier all seems to be working correctly. I am now going to check carbs what do I need to do
Jon Ison
| posted on 25/1/10 at 05:22 PM |
is your fuel pump on its way out ?
Keeping up on lite throttle settings but cant keep up when the loud pedal is depressed ?
bowood14
| posted on 28/1/10 at 07:16 PM |
AIR BOX / AIR FILTER
So this evening in the cold and wind!! I removed the air box, changed the filter back to original, checked all the rubber fixings to the carb,
resecured the box together, ensured it was all tight and hey presto it flies again. Now to work backwards and find what was wrong Thanks to all for
the suggestions Now I can continue with all the other mods needed for summer trackdays!!!!
[Edited on 28/1/10 by bowood14]
cosmick
| posted on 28/1/10 at 08:53 PM |
Hi Bowood,
your problem would suggest that the new filter was either not sealing or flowed significantly more air than the original. this would mean that with
the CV carbs as fitted to the blade, the depression on the carb side of the filter was not enough to raise the slides. the consequence is that it will
idle perfectly but will bog down when applying the throttle under load. opening the throttle even more causes the carbs to suck more air but
insufficient fuel.
by the way, it was me who balanced and set your carbs up when your car was at Mikes house.
