aka Keith
| posted on 11/2/10 at 09:14 AM |
Starter motor issues
My Zx9r starter does not always spin.
I can hear the relays click at the battery and the juntion boxes.
I have a new wire from battery relay to starter motor.
But sometimes, it does not work. Any ideas for further investigation.
Craig
r1_pete
| posted on 11/2/10 at 09:29 AM |
1st, all connections, check they're clean and tight, a loose connection arcs and soots up causing such problems.
That there is 12+v at the starter motor terminal when you hit the button, if not check the relay - worth checking anyway for continuity when
activated.
Then on to more detailed things like brush length, commutator segments bridged and arcing - as well trying to pick up another motor at this
point.....
[Edited on 11/2/10 by r1_pete]
pewe
| posted on 11/2/10 at 02:05 PM |
Had a similar problem on mine (albeit car starter).
Checked, cleaned and replaced most of the obvious items but still was intermittent.
Finally took it to a specialist (Burghfield Starter & Alternator Centre - recommended) who reported that half the windings were duff.
Cheapest option (his suggestion) was to buy a new/secondhand one off the 'bay.
HTH.
Cheers, Pewe
