Andy W
| posted on 27/4/04 at 08:53 PM |
ZX9R oil pick up
I've just removed the sump of my zx9 to have it chopped, and was just wondering whats the best way to shorten the oil pick up. I've seen
some good photo's of modded sump's on the site, but any help with the pickup would be useful.
Cheers Andy
Chris7
| posted on 28/4/04 at 07:11 AM |
that makes 2 of us
I removed mine to have it shortened i also need to know how to shorten the plastic oil tube with the guaze at the bottom as i think this is a major
component for the oil collection
any advice is welcome .
Thanks Chris B
ChrisGamlin
| posted on 28/4/04 at 11:01 AM |
Send it to my uncle and he'll do both for £50
Seriously though, if you want to have a go yourself then here's what I know of what he does.
He chops the tube off the trumpet part, then I think machines the narrow end of the trumpet to have a hole that allows the tube to slide snugly down
inside it (you could just cut it to shape if you were very careful). He then chops the tube to length leaving a couple of mm to act as a flange inside
the trumpet, then its all sealed back together using glue (not sure what - superglue would probably work well on that plastic tho)
Obviously remember to measure the height of the pickup in relation to the un-modded sump as it is, then dont chop the pickup until after the sump has
been chopped so you can get it all exactly the right height again.
Chris
[Edited on 28/4/04 by ChrisGamlin]
Andy W
| posted on 28/4/04 at 09:09 PM |
Thanks Chris
I'm geeting the welding done as a favour, so I think I'll have a go at the pickup, the way you describe sounds ok to me
Cheers Andy
Karl H
| posted on 20/3/13 at 10:33 PM |
ZX9 oil pick up
I know this subject is old but if anyone still needs to do this see my photos to see how i shortened the ZX9 oil pick up. it holds itself together but
i will seal with some gasket seal.
loony
| posted on 21/3/13 at 12:58 PM |
How long is this removed piece of oil pick up ?
  ZX9 oil pick up
Is it equal length to the part chopped from oil sump ? (it's logical, but I preffer to ask)
Little OT - will you use sump baffle plate ?
Lucas
Karl H
| posted on 21/3/13 at 07:51 PM |
Hi Loony, No its not the same, I cut out the strait section of the pick up, leaving aprox 5mm on the connector end so i had something to push inside
the funnel end, I opened the hole in the funnel end a bit with sand paper and I sanded down the connector to fit inside the funnel. shortened it by
about 30mm. when you shorten the sump take into account the thickness of the the baffle plate and gaskets and 8mm under the pick up for the little
lugs that stops the pick up from touching the bottom of the sump.
I am new to this forum, how did you put the picture in your reply? I was trying to do this but gave up.
loony
| posted on 21/3/13 at 11:42 PM |
Thanks for the info.
How much did you chop your sump ?
Do you have sump baffle plate ? Do you have any CAD drawing of it ?
To insert photo from your or someone else photo archive, just copy "forum code" that you can find over picture in archive.
Lucas
Karl H
| posted on 22/3/13 at 01:14 AM |
Hi Loony, I refitted the shortened oil pick up to the engine, and measured how much it would protrude into the sump then added 8mm for the lugs took
away 2mm for the baffle and that's how much I left on the sump if you see what I mean. Before I get it welded up I will fit to the engine and
measure exactly what size the lugs I need to make, fingers crossed i got my measurements right don't want less than 8mm space under the pick
up.
I got my baffle plate from this guy, Jonathan Rarity www.rarity.freeserve.co.uk/
very helpful Chap.
