Author: Subject: Just after re-assurance... i think...
Major Stare
posted on 24/3/10 at 09:51 PM Reply With Quote
Ran the 5PW R1 last week for the first time since fitting a new clutch, oil change and baffled plate for sump.
Question...
Drove 5 miles to a pub and left car for 2hours. Fired it back up and left it to warm up (about 5min), i then got a Critical Alarm on the DigiDash saying water temp was 105deg.
When doing the baffled plate, i removed pipes from inside the block/sump and re-fitted... have i caused a problem?
Oh, do i need to link the two outlets on the TB's as in this pic (NOT MY CAR)?
Jon "FISH"
Paul TigerB6
posted on 24/3/10 at 09:56 PM Reply With Quote
Sounds like you could do with raising the alarm temperature a bit there. The thermo unit doesn't switch the fan until around that sort of temperature.
Those two pipes look like the breathers so no need to link them together.
jack_t
posted on 24/3/10 at 10:12 PM Reply With Quote
looks like you have also removed the thermostat off the top of the block so hot coolent will just come out the top of the block to the radiator and looks like your coolent sensor is top right of your picture so if its still warm it might get hot pretty quick
Paul TigerB6
posted on 24/3/10 at 10:19 PM Reply With Quote
The thermostat is just under the nose cone on that car - repositioned as it would probably have fouled the bonnet in its original position (and isnt the OP's car anyway) D.
That sensor in the pic looks like a standard one for a dash temperature gauge. The 5pw comes with a combined thermo unit from memory that provides a signal to the ECU as well as operates the rad fan
Major Stare
jack_t.... that pic isnt my car, just to show the plumbing on the TB's. My sensor is mounted remotly.
Car ran fine for 500miles last year with no temp probs, im just concerned it ran hot (if 105 is high for a bike engine) after the mods ive done!?!?!
Jon "FISH"
Moorron
posted on 24/3/10 at 10:35 PM Reply With Quote
nope both my bike engines run upto 115 c and the fans control it so its normal.
up the temp to say 110 and if the alarm goes off then try 115 and if still alarm goes off then you have a problem.
The vents are the carb 'breathers' and dont need to be joined, just dont block them up.
Sorry about my spelling, im an engineer and only work in numbers.
bassett
posted on 25/3/10 at 12:49 PM Reply With Quote
My 5PW cuts in at 96-97 deg and only mods to the loom are for a remote switch for certain situations
