Author: Subject: 5VY R1 exploded diagram of clutch anywhere?
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 27/3/10 at 01:32 PM Reply With Quote
I stripped out the broken clutch and basket. It is a barnett set up. I have the replacement clutch soaking in oil. However, in my box of bits from the last owner, there is a length of wire, about a foot long and 'clutch retaining wire' is written on the packet.
I didn't see one of them stripping it??
Any exploded diagrams anywhere?
Ed
Johneturbo
posted on 27/3/10 at 02:20 PM Reply With Quote
Can't help with the barnett set up
but when i blew up my clutch, i was advised to remove the sump as parts of the friction plates can fall down.
thankfully i did as lots of bits were stuck to the oil pick up strainer
depending how bad ur clutch failed of course
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 27/3/10 at 03:54 PM Reply With Quote
Yep cheers, I had already asked about that on another thread. Just to complicated things, it is a dry sump!
progers
posted on 27/3/10 at 04:31 PM Reply With Quote
The thin wire you refer to is the retainer for the anti-judder plates at the back of the clutch (basically a smaller than normal clutch plate with some other metal rings).
It maybe the case that this had been removed by the previous owner and a normal clutch plate put in its place. This is often done by racers as it helps beef up the clutch. If you look at your clutch plates you will probably find they are all normal size. If this is the case you don't need this wire and you will need 1 more clutch plate than comes with a normal set of clutch plates from the dealer (don't use the small one in the pack). I often put one of the better old plates at the back of the clutch to make up the correct number :-)
- Paul
P.S. This refers to the 5pw clutch - I believe the 5VY is very similar
[Edited on 27/3/10 by progers]
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 27/3/10 at 06:14 PM Reply With Quote
Nice one paul, thanks.
It is an ex-rgb car, and all the clutch plates were all the same size.
I was a worried that there was an mashed wire somewhere in there!
posted on 27/3/10 at 06:21 PM Reply With Quote
Have a look on the Bike Bandit (US) website. They have exploded diagrams for most bikes. Hope it helps....
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 27/3/10 at 08:34 PM Reply With Quote
Took me a while to find it due to the Stella effect, but spot on diagrams. Thanks a million!
Ed
