Author: Subject: oil filter trouble
surferboy
posted on 23/4/10 at 07:12 AM Reply With Quote
oil filter trouble
Having abit of trouble getting the old oil filter off , i think its been welded on , short of hammering a screw driver in it and trying to turn it anybody got any suggestions ?
Its a 2003 R1
MakeEverything
posted on 23/4/10 at 07:14 AM Reply With Quote
have you tried a filter wrench or a strap spanner?
Kindest Regards,
Richard.
Paul TigerB6
posted on 23/4/10 at 07:15 AM Reply With Quote
Have you tried a proper filter removal tool yet? They generally work very well
v8kid
posted on 23/4/10 at 07:25 AM Reply With Quote
Screwdriver sounds good - done that a few times myself. Use a towel below it to catch the oil just don't let her indoors see you doing it
StrikerChris
posted on 23/4/10 at 07:29 AM Reply With Quote
screwdrivers all very good untill it still wont budge and rips through the can,then your proper stuffed!
skinned knuckles
posted on 23/4/10 at 07:38 AM Reply With Quote
strap spanner has never let me down
A man isn't complete until he's married, then he's finished
Guinness
Are you trying to remove it from a cold engine? Try getting the engine up to temp?
posted on 23/4/10 at 08:01 AM Reply With Quote
I've got one of the bike-chain type removers. The teeth on the cam are pretty viscious and although they destroy the filter can they tend to get it off!
tomgregory2000
posted on 23/4/10 at 08:08 AM Reply With Quote
the BEST tool is from draper and its a 3 legged filter wrench that takes a square drive in the center and the 3 legs are on gears and the harder you turn the wrench handle the harder the legs bite into the filter, ill try and find a pic
tomgregory2000
posted on 23/4/10 at 08:11 AM Reply With Quote
this one click me
surferboy
posted on 23/4/10 at 08:26 AM Reply With Quote
I like the look of the look of that draper tool , me thinks i'll give that ago
Stott
posted on 23/4/10 at 08:31 AM Reply With Quote
they sell that in halfords too, that's where I got mine
Here
[Edited on 23/4/10 by Stott]
FFTS
posted on 23/4/10 at 09:26 AM Reply With Quote
Halfrauds chain remover is a bit more locost
Chain Linky
[Edited on 23/4/10 by FFTS]
Chris.
contaminated
posted on 23/4/10 at 10:34 AM Reply With Quote
In my very earlier car tinkering days I built a 1974 de-seamed mini. When it came to servicing it I couldn't remove the oil filter either. I resorted to a screwdriver through it, at which point I realised it was the early type with a bolt-on outer case and an internal cartridge! A 13mm spanner would have had it off in 2 mins! Then I couldn't find a replacement for love or money Lesson learned - I have a proper tool now!
surferboy
posted on 23/4/10 at 05:22 PM Reply With Quote
Finally got it off with a bit of brute force and ignorance , and with the help of a strap spanner of course
