Major Stare
posted on 28/4/10 at 10:21 PM |
Just a quickie.... how do.....
Paddle shifters fit the steering column?
Jon "FISH"
blakep82
| posted on 28/4/10 at 10:37 PM |
a rod end above and below the collumn (fitted to a plate around the collumn) and the shifter is fitted to the rod ends is a good way. doesn't
*actually* fit to the collumn.
having said that i haven't got one, don't really like them myself either, so never thought too much about them, but thats how i seen them
before
________________________
YQUSTA
| posted on 29/4/10 at 07:50 AM |
Also depends on if you mean with or without a shroud?
"If in doubt flat out"
Colin McRae
Andi
| posted on 29/4/10 at 08:15 AM |
I think photos of fittings would be good at this point
Major Stare
| posted on 30/4/10 at 09:15 PM |
Had a look at my steering column today.
The column that comes out the dash turns with the steering wheel.
The outer collar is behind the dash and clamped to a metal bar/support directly behind the dash, with the collar going down to the foot well before
the centre column exits and joins the rest of the steering column.
My options seem to be.... extend the outer colomn from behind the dash to the other side of the dash, then fit paddle shifter.
Perhaps weld a tube to the end of the outer column???
Hope this makes sence
Jon "FISH"
