corrado vr6
| posted on 2/5/10 at 09:23 PM |
R1 engine mounts
Evening all, Im after an m10 x 1.25 fine pitch bolt for the top mounting of my R1 engine i already have a set but there only 110mm long which is fine
for one side but on the other it needs to be more like 120-130mm in length after doing a search i see some people had sets for sale but this was back
in 2007, can anyone help me out with this or know of somewhere i can get a bolt of this length.
also for the middle and lower side mountings during the build i have just used m10 threaded bar but with IVA approaching and for piece of mind id like
to change these to bolts as from reading some old posts its frowned upon to use threaded bar, so again can anyone help me out or know of a supplier
that will be able to help me.
Thaks in advance Greg
http://r1indy7.wordpress.com/
ReMan
| posted on 2/5/10 at 09:41 PM |
Most bike breakers should help if you show them what you need, theyre standard enough bike fasteners
corrado vr6
| posted on 2/5/10 at 10:11 PM |
Thanks for your reply/suggestion, but by my understanding standard bike bolts will not be long enough for my use, but i will make some phonecalls to
be sure
phelpsa
| posted on 2/5/10 at 10:18 PM |
I may well have a pair in the garage that I didnt make use of as my engine doesnt have those mounts.
