Author: Subject: Power Commander instructions
GreigM
posted on 3/5/10 at 03:31 PM Reply With Quote
Does anyone have instructions on how to use the 3 buttons on the faceplate of a power commander? Want to lean-out the MoTable range for MoT tomorrow, but have no instructions and can't get the powercommander to talk to my laptop - so stuck with the buttons and no clue!
Paul TigerB6
posted on 3/5/10 at 03:33 PM Reply With Quote
linky
GreigM
posted on 3/5/10 at 03:35 PM Reply With Quote
unfortunately all those links are dead
adithorp
posted on 3/5/10 at 06:49 PM Reply With Quote
From memory...
1. Press and hold all three buttons and then switch ignition on.
2. Release buttons and press the one corresponding to the range you want to alter. By repeatedly pressing you'll see the tell tale LEDs move up and down.
3. Stop pressing when it's at that level you want.
4. Repeat for any other area you want to alter.
I think there's a time limit between stage 1 and 2 so be quick. It'll take a while to get the hang of it.
adrian
http://jpsc.org.uk/forum/
GreigM
posted on 3/5/10 at 07:35 PM Reply With Quote
Thanks adrian - with your guidance I've figured it out....for reference you push the button to make the display go up, hold it down to make it drop....
So fingers crossed if i put the low range down significantly it'll be enough to get through the MoT...
