carpmart
| posted on 14/5/10 at 10:16 AM |
ZX9 Big end bolt torque
Guys
Does anyone have the torque for the big end bolts on a ZX9 engine.
Many thanks in advance for you help!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
mistergrumpy
| posted on 14/5/10 at 07:51 PM |
Connecting rod bearing cap bolt nuts:
New con rod assembly (using nuts and bolts supplied with the rod)
Stage 1 18Nm
Stage 2 Angle tighten a further 120 degrees
New con rod assembly (using the bolts supplied with th rod but with other new nuts)
Stage 1 20Nm
Original con rod assembly (using new bolts and the original nuts)
Stage 1 24 Nm
Original con rod assembly (using new nuts and bolts)
Stage 1 25 Nm
