Major Stare
posted on 15/5/10 at 03:34 PM |
Loss of neutral gear
I have fitted a paddle shift with cable.
Test dirve today, started car, pulled for first gear and drove off, then second. Seemed fine.
Got to junction at end of road and i couldnt find neutral
Tried everything and gave up, managed to find 1st and drove home.
Is it a case of fine tuning?
If so how?
Jon "FISH"
doddy
| posted on 15/5/10 at 03:50 PM |
cant say for cars but on bike somtimes it happens and you just need to adjust the gear lever position a little as neutral it like a half gear change
so it need to be spot on other wise it just goes to secound
ReMan
| posted on 15/5/10 at 07:04 PM |
I can't imagine there is anything to tune?
Getting neutral is amore about technique.
Try to hook it before you come to a complete stop.
Most of the time best not to use it, it just wastes fuel
Major Stare
| posted on 16/5/10 at 05:59 PM |
I need to check everything over during the week because i spent 10mins rocking the car on the drive so i could push it into the garage... neutral was
non existant ??? :arse:
When i select a gear, could i be pushing too far and skipping between 1st and 2nd?
Jon "FISH"
40inches
| posted on 16/5/10 at 08:00 PM |
You just need a light prod to get it to fall out of gear and into neutral, how much throw have you got on the lever? too short will make it difficult
to feel, try taking gear knob off and slipping a short length of tube over stick to extend it about 3 inches and see if it feels better
B*m! that will teach me to read the OP post carefully but the theory is the same, just the execution that is different, may just be down to
leverages and lever throw.
[Edited on 16-5-10 by 40inches]
| posted on 16/5/10 at 10:18 PM |
On my bike I always have to go down into first to come back up into neutral, it will not go in from second gear and needs a light touch to get it not
a proper lift.
progers
| posted on 17/5/10 at 07:05 AM |
If I remember correctly, you have recently fitted a barnett clutch conversion with heavy duty springs.
You might find that, even with your clutch fully disengaged, there is some "drag" between the steels and friction plates of the clutch.
This may be caused by not having quite enough travel on the clutch to fully release the clutch (Be careful not to overpull the clutch). If thats not
the case, its just a learning curve on how to best find neutral. I find it better to go down to 1 and then use both hands on the paddle shift to
"nudge"the gear into neutral. sometime a blip on the throttle helps.
Paul
s2gse
| posted on 21/5/10 at 08:16 PM |
loss of neutral gear
i had the same with mine wouldnt go into neutral with the engine running but fine went the engine was off on the GSXR found i needed to ajust the
clutch cable a bit more there was to much play
