Author: Subject: ZZR1100 engine install.
jossey
posted on 29/5/10 at 12:46 PM Reply With Quote
im just about to start the install of the engine (zzr 1100 1993) but i hear i need a smaller sump. is that the case?
my build is a book spec ron champion locost.
all body panels are the GRP parts.
has anyone done a zzr1100 engine? any advise?????
zilspeed
posted on 29/5/10 at 12:53 PM Reply With Quote
GPZ900R sump and pickup are what you require.
lotusmadandy
posted on 29/5/10 at 01:09 PM Reply With Quote
Dave,
You need to talk to guinness.He has that lump in his indy and know's his stuff.
Send him a u2u,i bet he can help.
Paul TigerB6
posted on 29/5/10 at 03:50 PM Reply With Quote
one of these ??
CraigJ
Just fitted a GPZ900 sump n pick up to my zx10. its 40mm shorter. fits a treat.
Got mine from this seller
http://myworld.ebay.co.uk/skycaptain_789/
Ask him for the pick up pipe also. charged me £19 all in posted.
jossey
posted on 29/5/10 at 04:28 PM Reply With Quote
thanks again all.
Guinness
posted on 29/5/10 at 05:08 PM Reply With Quote
My ZZR just fits in the Indy. The top of the foam filter on the carbs just fits tight up against the underside of the bonnet bulge. The rest of the engine fits down from there. I'll see if I can find a couple of photos of my engine cradle, as designed by MK in a moment.
The GPZ sump is as everyone says shallower than the ZZR one, which gives you a useful increase in clearance. However, be very careful when swapping the hoses over. Label everything before taking the ZZR one off, and make sure you compare the internal oilways in both sumps before fitting the GPZ one.
The ZZR runs a two stage oil pump, out to the cooler and back to the sump, then through the filter and up to the main galleries. However it also has an external feed hose to the head and a rigid external pipe to lubricate the clutch / gearbox. Make sure you get all of these connected up to appropriate outlets on the GPZ sump. I think from memory that one of the outlets in the base of the sump on the Zed is replaced by one on the side of the GPZ, but don't quote me on that.
If I was installing mine again, I'd move it forwards by about 3". I doubt it would make lots of difference to the handling of the car, but it would allow me better access to the far end of the engine, where the oil sight glass, timing cover etc are located.
If you need anything else, just ask.
Mike
2 Cradle
2 Cradle
1 Cradle
1 Cradle
Photos of sumps are in this folder:- http://www.locostbuilders.co.uk/photos.php?action=gal&user=Guinness&folder=ZZR%20and%20GPZ%20Sumps
[Edited on 29/5/10 by Guinness]
INDY BIRD
posted on 29/5/10 at 05:20 PM Reply With Quote
i fited this to mine running a dry sump kit
not locost though
cheers
link
http://www.muzzys.com/11DODS/index.html
jossey
posted on 29/5/10 at 07:42 PM Reply With Quote
thank you so much guys.
