Author: Subject: 4xv R1 any good
sdh2903
posted on 9/6/10 at 07:03 PM Reply With Quote
4xv R1 any good
Ive found an R1 package at a very good price, its a 99 4xv on carbs and its done low miles
Is this the model of R1 that suffers with gearbox issues? Is it suitable for kitcar installation?
cheers
[Edited on 9/6/10 by sdh2903]
Davg
posted on 9/6/10 at 07:52 PM Reply With Quote
Steve would that be the one that was on fleebay?
GeorgeM
posted on 9/6/10 at 07:55 PM Reply With Quote
engine will fit & work fine, but 2000-2001 5JJ does have a better gearbox
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
A1
posted on 9/6/10 at 07:59 PM Reply With Quote
third gear on my 03 one feels like running a stick through margarine...
good engines though, and the gears are only 80quid to replace.apart from first (140iirc)
sdh2903
posted on 9/6/10 at 08:12 PM Reply With Quote
The one up north? if so than yes, is there something i should know?
smart51
posted on 9/6/10 at 08:17 PM Reply With Quote
I liked them so much I had two! And rebuilt the bottom end of the second one. Lovely noise. Good speed. Better gearing for a car than 04 and later engines. Tricky emissions for IVA. Neither of mine were that reliable. A bit like what Clarkeson says about Alfas. You've got to live though the pain for those glorious moments when it all works.
locoR1
posted on 9/6/10 at 08:27 PM Reply With Quote
I would highly recommend the 4xv, my engines been in the car about 5 years now the last 3 turbocharged if it can handle 257hp turboed you should be able to thrash it all day long without blowing it up!
Check out my CB500T Cafe Racer build diary
Davg
posted on 9/6/10 at 08:28 PM Reply With Quote
Steve, no panic I nearly bought that for the store cupboard, very very good price considering. If you have made your mind up on going BEC, give me a shout I have 2 R1's at the mo one with the same engine you are looking. Easy Peazy install if you go for it.
send me a u2u if you fancy letting me know how much the deal is
cheers D
sdh2903
posted on 9/6/10 at 08:34 PM Reply With Quote
Dave you have a pm!
Davg
posted on 9/6/10 at 08:47 PM Reply With Quote
Sorted
A1
posted on 9/6/10 at 11:22 PM Reply With Quote
i must say, i dont think i do a drive without giving it a good thrashing, lasted very well considering...
