| posted on 23/6/10 at 01:22 PM |
Kawasaki 1400 Engines...
Anyone know the technical differences between the ZZR1400 and the GTR1400?
Obviously the ZZR makes a fair bit more power, but is that just the electrickery and injectors, or are there mechanical differences inside the
engines?
Cheers!
It's Evolution Baby!
paulf
| posted on 23/6/10 at 01:34 PM |
The gtr has a variable valve timing system.I had the chance of one but it had no keys and the ECU is matched to the keys so needed a new ECU and keys
or after market one.I decided against it due to the variable valve timing .
Paul
Hammerhead
| posted on 23/6/10 at 01:43 PM |
Scootz have you seen these 3 wheelers:
http://www.sub3wheeler.com/
vw gx3
There is also a home made one by a guy in sweden or denmark, I will try and find the link.
Steve.
daviep
| posted on 23/6/10 at 01:47 PM |
There are quite a few differences.
1; The GTR has a lower CR, different pistons I think.
2: The GTR has a higher primary reduction so the crank and clutch basket are different
3: Crankcases are different part numbers
4: GTR has an extra oil feed, I think for the bevel box.
5: Gear ratios are different.
Probably more but I stopped checking.
You been looking at the same engine I was?
Davie
| posted on 23/6/10 at 01:54 PM |
Think so Davie... the one on eBay at £1050 or 'best offer'???
| posted on 23/6/10 at 01:55 PM |
vw gx3
Steve.
That's pretty cool!
daviep
| posted on 23/6/10 at 02:02 PM |
Yeah
afj
| posted on 23/6/10 at 02:30 PM |
zzr is chain driven
gtr is shaft
eerrrrrrrrrrrrrrrr
