Author: Subject: Ground Clearance
Nick DV
posted on 8/7/10 at 04:18 PM Reply With Quote
Ground Clearance
What do most people have as the minimum clearance between the bottom of the sump and the black stuff, that they can get away with, without any serious grounding?
I have 60 - 65mm, (2 1/2 inches in old money), and will have a skid pate in place for extra protection.
I know that the problem could be made worse with a soft suspension set up, but most kit cars hardly move on the suspension,
Cheers, Nick
"The force will be with you, always!"
Danozeman
posted on 8/7/10 at 04:27 PM Reply With Quote
Thats not alot. MIne has about 10cm. It did have less and it did bottom out.
Dan
Humbug
I think I've got about 4" including a skid plate. I occasionally scrape the plate but I'm happier having the plate there than not. I think 2.5" would be a bit low
Nick DV
posted on 8/7/10 at 04:31 PM Reply With Quote
I do need to adjust the suspension to get the correct height but I will only gain about 15mm, 20mm at the most. I think I will have to suck it and see!!
Cheers, Nick
Nick DV
posted on 8/7/10 at 04:37 PM Reply With Quote
Forgot to say, my car will NOT be used on the road as it's for track use only,
Cheers, Nick
speedyxjs
posted on 8/7/10 at 04:38 PM Reply With Quote
My ground clearance:
1 1/2"
To be fair, it is now 2" and should be about 3" when i fit front suspension.
speedyxjs
posted on 8/7/10 at 04:39 PM Reply With Quote
Cheers, Nick
If it is for track, it shouldnt be much of a problem at the height you have it. most circuits are pretty smooth.
Nick DV
posted on 8/7/10 at 04:43 PM Reply With Quote
I agree, just wanted to see if anyone had any probs,
Cheers, Nick
2cv
posted on 8/7/10 at 05:07 PM Reply With Quote
quote: I know that the problem could be made worse with a soft suspension set up, but most kit cars hardly move on the suspension,
Nick, Hi. In my experience unless you are racing, on the road, the car will handle better with the dampers set to fully or almost fully soft because you will have no control if the car bounces from bump to bump. Spring rates have to be sensible too ie not too high. As a trade off you'll need a bit more ground clearance perhaps four inches but I doubt you'll notice much difference in handling and you'll not have the stress of worrying about bottoming out on raised ironwork or sleeping policemen.
With a compliant suspension set-up you'll have a very comfortable ride and the car will be a pleasure to drive. I have to stress that this is only my opinion but derived from experience.
ps whilst writing this I note that you have added that the car will be for track use only.
[Edited on 8/7/10 by 2cv]
norfolkluego
posted on 8/7/10 at 05:58 PM Reply With Quote
Cheers, Nick
Unless you get your front wheels either side of one of the kerbs
macc man
posted on 8/7/10 at 06:00 PM Reply With Quote
If you have a steel sump it would not take much work to cut and shut it to give extra clearance. An alloy sump is harder but still fairly easy. My clearance is about 3inches but is for track use only.
Stuart_B
posted on 8/7/10 at 06:07 PM Reply With Quote
hi, i have 1 1/2" ground clearance, no only one grounding, which did make a pin hole leak in the sump.
stuart
posted on 8/7/10 at 06:54 PM Reply With Quote
80mm. No rubbing, can just get over beam at MOT time.
RichardK
posted on 8/7/10 at 07:47 PM Reply With Quote
3" and ground fairly often when I forget and go over those stupid little square speedhumps that tend to be placed on blind bends etc which is really safe when having to straddle them in the middle so you can get over them!!
My button has just been pressed.
Rich
Gallery updated 11/01/2011
matt_gsxr
posted on 9/7/10 at 09:43 PM Reply With Quote
10cm for me. We have killer speed "cushions" on our road. But my sump is a billet one and its bottom is level with the bottom chassis rail.
Remember you track only chaps that you need to get the car on and off the trailer.
dilley
posted on 10/7/10 at 11:23 PM Reply With Quote
14" for me, I hope when it's finished it doesn't bottom out!
40inches
posted on 11/7/10 at 08:56 AM Reply With Quote
350mm what you building? a Hummer
