joni
| posted on 11/7/10 at 12:45 PM |
water hoses 919 blade
hi has anyone got a pic of there water hoses on a blade bec thanks
ie header tank top hose or bottom
rad to thrmo top hose and bottom hose
thanks jon
gixermark
| posted on 13/7/10 at 07:40 PM |
hi matey....
3 pipes to plumb the blade in..
top of water pump housing - send straight up to expansion tank/bottle.
The other pipe from the water pump into the botom of the rad.
Then link the outlet from the thermostat over to the top of the rad..
The small nipple up out of the thermostat housing is ideal to have a take off pipe to block off - use for bleed..
I've no pics of mine - but shout if you need anything..
See you at the rock !!
joni
| posted on 14/7/10 at 07:07 PM |
thanks mate
