david cromie
| posted on 29/5/04 at 11:40 PM |
ht leads
where can one buy a length of ht lead that will keep the sva man happy. cannot locate any over hear except the copper wire type whch i am told will
not pass sva as they cause interverence. david
scoobyis2cool
| posted on 30/5/04 at 12:18 AM |
I bought one from Halfords the other day, they do all sorts of lengths from about 15cm up to nearly a metre
Pete
alister667
| posted on 30/5/04 at 11:12 AM |
Hi David,
I wound up buying 4 HT coil leads (Silicon 15kOhm hotwires) and butchering them then fitting the blade lead ends to these. They only cost 1-2 quid
each and were long enough OK.
Good Luck
Ali
http://members.lycos.co.uk/alister667/
| posted on 30/5/04 at 10:34 PM |
alister - that's what we did. Make sure they are the 7mm diameter one's, the 8mm are very tight!
Never had a problem since...
