Author: Subject: Busa fuel pipe
Davegtst
posted on 23/7/10 at 07:16 PM Reply With Quote
Busa fuel pipe
Am i right that my busa will only need a feed pipe from the in-tank fuel pump and won't need a return. If so how does it regulate fuel pressure?
doddy
posted on 23/7/10 at 07:48 PM Reply With Quote
the pump has a regulator in it
:{THC}:YosamiteSam
posted on 24/7/10 at 12:29 PM Reply With Quote
not all of the bikes had it -according to haynes they put the fuel pump and regulator in the tank in 2001 - so if your engines beefore that it may have a return - just look for a return pipe to it
Davegtst
posted on 24/7/10 at 03:45 PM Reply With Quote
Cool thanks. Mine is later than 2001 so just one pipe then.
Jon Ison
posted on 24/7/10 at 05:09 PM Reply With Quote
Just a word of caution but its your call,
If you run the busa pump in the tank you will have a high pressure fuel line from back to front, not something personally I would want it will also be prone to Air locks until its properly bleed which could be a while, I have heard of people getting airlocks in the system done this way. Remeber its just a short little run on the bike ?
cosmick
posted on 24/7/10 at 10:00 PM Reply With Quote
I have been running a Suzuki fuel pump in my car for 2 years now. Never had any problems, the pressure is constant and the fuel line run is simple as there is no return back to the tank. i am amazed at how complicated some people have made their supply of fuel to the engine. Keep it simple and use the pump that Suzuki designed for it and i can say you will be pleased with the result. Even if you have a pre 2001 engine, you can still run the later type pump. you just have to remove the old pump from the rail and have only one supply to the rail.
See my Photo archive for the pre and post modification.
cosmick
If it can't be fixed with a hammer then its probably an electrical problem.
:{THC}:YosamiteSam
posted on 25/7/10 at 11:24 PM Reply With Quote
aye 2nd'd - i have a fuel pump right down near the diff to the engine - works fine
Gerhard
posted on 29/7/10 at 06:11 PM Reply With Quote
You have full pressure in the fuel line in a normal system also
Jon Ison
posted on 29/7/10 at 08:10 PM Reply With Quote
Full potential pressure of the lift pump yes, 3 psi in my case, that's a lot less than the 50 or so a hp pump delivers, its personal choice but having had a fuel line rupture in the past I prefer not to have 50psi + behind it, not that a low pressure leak is advisable either.
