Author: Subject: mnr project zzr1400 engine update
INDY BIRD
posted on 26/7/10 at 12:12 PM Reply With Quote
well got the engine diagnosis back on the old venom project mnr,
its good a proper done in,
crank cams rods head etc all blued up so engine is a expensive coffe table now,
will be getting a new engine as crank alone is over a grand,
still expected it to be that way with no oil in it,
will look to sell on the good bits i have been told the casing a gearbox fetch good money,
cheers all still smilling though
fesycresy
posted on 26/7/10 at 12:22 PM Reply With Quote
Are you saying they put that on a rolling road with no oil in it ?
Rocket_Rabbit
posted on 27/7/10 at 01:18 AM Reply With Quote
Wow...if that is the case, i'm horrified, and having read the story behind VP, totally devastated for him
INDY BIRD
posted on 27/7/10 at 10:13 AM Reply With Quote
hi all there was oil in the engine but just not lubricating the bits that need it ie the bits that are niw no goof, the oil pick up was modified and may have caused the issue as they had castled this to help with the lower sump, we will never know all we know is oil was in the engine but not lubbing the engine could be the accusump ??? Taking the oil ?? Or the oil pick up ?? Still it was a shame , i wiil be putting on andy bates billet sump and new higher pressure relief valve to help the new engine no one is to blame its just one of those unlucky things a combination of things can make it work or fail, i was only posting to show results not to point the blame not getting into that one, thanks all
franky
posted on 27/7/10 at 11:36 AM Reply With Quote
so an incorrectly set up accusump? i guess the accusump was full of oil?
INDY BIRD
posted on 27/7/10 at 03:05 PM Reply With Quote
accusump is a possible explination to the problem they do work as i have used them on two cars before but need to plumb them direct to an oil gallery to mist effective
franky
posted on 27/7/10 at 05:01 PM Reply With Quote
I don't see that as the issue, maybe that when it plumbed in it just wasn't set up correctly, right amount of air in the 'pump' etc so when the engine was run the oil went into the accusump causing starvation?
INDY BIRD
posted on 29/7/10 at 09:29 AM Reply With Quote
yep thats very possible as i thinks you need around 7psi etc in there???
so will see if i even run it next time????
cheers
sean
imp paul
posted on 29/7/10 at 10:13 AM Reply With Quote
its a shame that its not savable but hope you get a good motor next time as for me i wont be going near a acusump kit all the best paul
[Edited on 29/7/10 by imp paul]
INDY BIRD
posted on 29/7/10 at 03:32 PM Reply With Quote
Thanks paul, prob wont use the accusump as the new engine and modified sump by andy should be all i need??
hows you engine these days got it all sorted yet?????
cheers
sean
franky
posted on 29/7/10 at 08:08 PM Reply With Quote
you can download an accusump set up sheet, as long as its done properly or at all they're great bits of kit, more reliable than a dry sump. Even with the AB sump it doesn't cover the area's an an accusump system would! Even using as a pre-oiling system its worth having on.
[Edited on 29/7/10 by franky]
imp paul
posted on 1/8/10 at 07:16 PM Reply With Quote
my engine is in bits at the moment all seems very good just got to size new shells for the new con rods and get the cam gears tiged on to the cams also get the large gear from the clutch basket fitted to the muzzy 1 i have a nova sump also very nice bit of kit you should be fine with that just hope you have better luck this time regards paul
Johneturbo
posted on 4/8/10 at 12:53 PM Reply With Quote
Indy bird just had a look at your photo archive, did you cut the main tub or are they now 3 piece tubs
also are your track rod ends the right way around i thought they should curve out towards the front, unless mine are the wrong way round!
INDY BIRD
posted on 5/8/10 at 10:46 AM Reply With Quote
hi
i have cut the tub myself to make it easier to work on will make a plate to cover this once re done,
the A arms i am not sure about this is how they came fitted would check with mnr as i will to just in case, as far as i am aware they checked this car over so should be correct perhaps ask others on the site or they may pitch in now
cheers
sean
