joni
| posted on 29/7/10 at 07:07 PM |
best place for temp sender
hi were is the best place for engine temp sensor do you put it closer to rad or engine
i have the in line alloy type
thanks in advance
engine is 929 blade
[Edited on 29/7/10 by joni]
mookaloid
| posted on 29/7/10 at 07:18 PM |
what is it sensing for? temp gauge? fan switch?
For a gauge I would say near the engine , for a fan switch I would say near the rad.
Mooky
mark chandler
| posted on 29/7/10 at 07:27 PM |
On my 919 blade I drilled out the bike temp sensor and tapped the hole to suit a car sensor so I could megasquirt it.
You must have one on the engine anyway, look on the head where the radiator pipe exists, it will be here abouts tapped in to the block.
Regards Mark
| posted on 29/7/10 at 09:21 PM |
Gauge sensor should go before the thermostat ideallly in the head, if you can't put in the head then in the by-pass flow.
Fan switch ideally goes in the radiator.
