Author: Subject: how hot
joni
posted on 15/8/10 at 09:41 AM Reply With Quote
how hot
how hot doz a rectifier get on a 919 blade engine get
thanks in advance
INDY BIRD
posted on 15/8/10 at 09:45 AM Reply With Quote
in short very hot,
fit it to a piece of ally to help disipate the heat or some have fitted computer fans above it to help keep it cool,
try to keep it in air flow to keep it cool,
or it may die,
thanks
RIE
posted on 15/8/10 at 12:34 PM Reply With Quote
What indy bird said, Honda regulator/rectifiers are notorious for burning out
matt_gsxr
posted on 15/8/10 at 05:59 PM Reply With Quote
Have you considered replacing it with more modern technology? The world of semiconductors has moved on.
http://www.triumphrat.net/speed-triple-forum/104504-charging-system-diagnostics-rectifier-regulator-upgrade.html
These fh12 are more efficient and generate no heat. What is there not to like? They are used on modern R1 and zx10r and probably others. No more expensive from a breaker than the fireblade one (I suspect).
Matt
