piddy
posted on 21/8/10 at 05:55 PM |
pluming
Hello All.
I have an old ball valve system in my mother’s loft tank that is dripping; I want to change the washer in it but can't seem to buy one. (Well I
could at my local pluming centre if I brought a box of assorted washers at £7.50)
It is larger than a standard ball valve system attaching directly to a 22mm pipe.
The washer is about 1" diameter by about 1/4" thick (it is a washer Not a diaphragm)
Can any of you advise me where I might buy one? Maybe on the net somewhere?
Martin.
goaty
posted on 21/8/10 at 06:08 PM |
i prob got one sitting here, i will check it out 2mo and whack one in the post if you need......
but to be honset a complete new type two valve would only be a few quid.....
piddy
posted on 21/8/10 at 06:39 PM |
Hi. I was thinking that a new unit wouldn't be too much, but firstly are the larger units readily available and secondly I can change the washer
without too much hassle.
Danozeman
posted on 22/8/10 at 07:49 AM |
Are you sure its 22 not 3/4? You can still get a new valve that goes straight to 3/4.
If you go to a proper old type plumbers merchant not a chain like plumb base then youl get a washer on its own no bother.
Dan
macc man
posted on 22/8/10 at 09:25 AM |
Get a plumber in to do it for you, we need the work!!!
Bigheppy
posted on 22/8/10 at 09:38 AM |
Temporary fix is to turn the washer round if its not already been done.
