chunky2772
| posted on 5/9/10 at 09:34 AM |
electric reverse mounted on engine!
i have pictures of my own designed reverse gear system ive made for my locost but carnt work out how to post pictures on here. this system works great
tryed it out yesterday im sure you lot will love this idea. this system mounts to the front of your propshaft and its fairly easy and cheap to make.
i,d love to share my idea so if someone can send me there email adress and post them on here for me that would be great. send to
bigchunky27@yahoo.co.uk and i will email you the pics so you can post on here (you wont believe how well this works)
mookaloid
| posted on 5/9/10 at 09:40 AM |
If you can upload the photos to your photo archive on here I'm sure we can help to show them in the thread.
chunky2772
| posted on 5/9/10 at 09:45 AM |
how do i upload a photo! i know i sound a right thick,o but im rubbish with computers took me all my time to work out how to post messages.
mookaloid
| posted on 5/9/10 at 09:52 AM |
click on the photo archive bit on the left below your name and location
then click the choose file button on the next screen to browse to where the photo is on your pc, ok that then click upload
Then let us know you have done it
chunky2772
| posted on 5/9/10 at 09:58 AM |
done just keeps saying unnsuported file type! contact chriss.
A1
| posted on 5/9/10 at 10:05 AM |
patent it and sell it for 150 quid a unit.
what type are your photos? if you open them and select save as, then you can change the type.
mookaloid
| posted on 5/9/10 at 10:25 AM |
save them as a .jpg and then try uploading them again
[Edited on 5/9/10 by mookaloid]
chunky2772
| posted on 5/9/10 at 10:39 AM |
sorry lads nothing is working will try later again tonight
eddie99
| posted on 5/9/10 at 11:22 AM |
Email the pics to eddie@skyships.co.uk and i'll put them up later on this afternoon.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
scudderfish
| posted on 5/9/10 at 11:40 AM |
From chunky :-
reverse gear, i used an austin mini starter motor ,a 125cc 80toothed rear go cart sprocket and a few links of go cart chain. take starter motor apart
weld links of the chain to a tube then weld tube to startemotor shaft . i also got a short of cut of 114 mm mild steel tube and two flanges laser cut
welded these together and bolted this to the engine flange adapter them skimmed the hole sprocket holder in the lathe to balance it job done!
statermotor just swings a across on to rear sprocket and reverses the car works excellent even with two people in the car. any turner could machine
this sprocket adapter for you.
Full gallery at http://picasaweb.google.co.uk/dave.g.smith/Reverse#
Davegtst
| posted on 5/9/10 at 01:44 PM |
Looks like a really neat setup. What engine is it mounted to? Wouldn't work on my busa as the clutch slave cylinder is in the way.
zilspeed
| posted on 5/9/10 at 02:59 PM |
Love the chain sprocket.
Rational thinking at its best.
chunky2772
| posted on 5/9/10 at 07:11 PM |
my engine is a k81000cc gsxr! ive done away with the clutch cylinder and made the clutch manual the boosa and gsxr are the same engine .
[Edited on 5/9/10 by chunky2772]
Davegtst
| posted on 5/9/10 at 07:37 PM |
How do you mean 'made the clutch manual? Interested to see what you have done, i had to make a new bracket to move the slave cylinder away from
the block to make room for the prop UJ.
[Edited on 5/9/10 by Davegtst]
chunky2772
| posted on 5/9/10 at 08:13 PM |
i have pictures off how ive done this but carnt seem to post pics on this site i can email you these if you send me your email adress my email is
thenorthface
| posted on 8/9/10 at 09:37 PM |
quote: Originally posted by scudderfish
From chunky :-
can you show some pics of how you engage the starter motor to the go kart ring ? really intersted in doing this for my sva test
WAYNE10
| posted on 9/9/10 at 05:20 PM |
This maybe just what I need how do you engage the starter motor to the go kart ring & did you have to move the bike clutch thingy as my blackbird
has not got much room by the prop flange?
chunky2772
| posted on 9/9/10 at 08:35 PM |
i just made a bracket to swing the startermotor onto the drive sprocket and used a mountain bike brake cable conected to a lever near my gearstick!
ive also connected the side stand switch to the statermotor so if the startermotor is in reverse the engine will cut out when in gear! the
startermotor has a push button switch on the dash you swing the motor onto the sprocket then press the button this then reverses your car with smooth
control this works fantastic as go cart sprockets are light weight and are made from realy hard aircraft grade aluminium this system reverses the car
great even with two people in the car i have about 10mm clearance between flange adapter and clutch bracket
thenorthface
| posted on 10/9/10 at 08:36 AM |
Put some pics up please
put some pics up please
hard aircraft grade aluminium this system reverses the car great even with two people in the car i have about 10mm clearance between flange adapter
and clutch bracket
coyoteboy
| posted on 10/9/10 at 09:10 AM |
Just watch out for water ingress into that starter, it's upside down and looks to be liable to leaving the bearings under water with a bit of
spray/rain if it's not covered.
MikeR
| posted on 10/9/10 at 09:38 AM |
It also looks like you need slightly longer bolts on the sprocket.
Excellent idea though.
chunky2772
| posted on 10/9/10 at 03:20 PM |
i carnt seem to post pictures in my archive! sorry tryed everything even changeing picture image nothing works! if you want pics i can only send by
email
