motorcycle_mayhem
| posted on 25/9/10 at 08:48 PM |
Suzuki OEM TB Connector Block
I'm looking for (ideally) just the pins for the Suzuki throttle body plug (16 pin square one) on a GSXR1000 (K1-K4).
Hoping someone has had a similar need and found a source???? My thanks.
cosmick
| posted on 25/9/10 at 09:54 PM |
Believe it or not, these terminals are available by part number from Suzuki. I have a packet of 50 male and 50 female (minimum quantity) and would be
willing to sell you some. They even come with the little rubber insulator for each terminal. You need a W type crimping tool if you know the type.
How many do you need and do you want male or female or both?
How does 20p each plus a bit of postage sound?
[Edited on 25/9/10 by cosmick]
If it can't be fixed with a hammer then its probably an electrical problem.
r1_pete
| posted on 26/9/10 at 10:32 AM |
Do you have the part numbers? my next next job is byilding the injector loom...
cosmick
| posted on 26/9/10 at 11:39 AM |
09900-28710-002 is the female
09900-28710-003 is the male
Remember you only need to order 1 of each as this part number is a pack of 50. No dealer will stock it so you will have to order it via a Suzuki
Motorcycle dealer. Someone like Robinsons (Canterbury) ,Fowlers (Bristol), Redcar Mcs (Leicester) or Crooks (Barrow in Furness) if your up North These
dealers all specialise in Parts so are well versed with phone orders and sending stuff out to customers.
[Edited on 26/9/10 by cosmick]
motorcycle_mayhem
| posted on 27/9/10 at 10:06 AM |
THANKS.... just didn't think it'd be found at the Stealers.
I've simply added a handy pack of 50 to today's order for the stuff to rebuild the bottom end of my engine after this weekend...
Thanks again.
