Author: Subject: Any guesses what TH/V is?
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 30/9/10 at 06:54 PM Reply With Quote
On my R1 5VY loom, there is a wire labelled "TH/V" . Anyone care to guess what that stands for? I made a note of all the connections as I took the duff motor out, and this wire is spare!!
Also, there is a wire from the bottom of the sump, a foot long or so, is that the oil temp sender? Or what is it? (last engine didn't have one as it was dry sumped).
Cheers all!
Ed
steve m
posted on 30/9/10 at 07:02 PM Reply With Quote
Surely a spare wire must have two ends ??
so were is the other end
[Edited on 30/9/10 by steve m]
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 30/9/10 at 07:09 PM Reply With Quote
The car is an ex-RGB racer, and had a custom loom made for it. The other end of the wire could be anywhere, consider it un-traceable as it dissappears into ever thicker trunks of wire!
Also, accordind to my Haynes, the other wire from the sump is oil level sender, so I guess I'll ignore it.
mangogrooveworkshop
code:
That is the oil level sender
I know that cause mine does not work
bigrich
posted on 30/9/10 at 07:32 PM Reply With Quote
th/v is it throttle valve? secondary butterflies or similar not sure how old a 5vy motor is
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 30/9/10 at 07:35 PM Reply With Quote
2005/6 ish?
Throttle position sensor is connected.
I cannot see anywhere to connect it! I'll give builders a ring tomorrow and see if they know.
Cheers all.
:{THC}:YosamiteSam
posted on 30/9/10 at 09:11 PM Reply With Quote
just wait n see what doesnt work
adithorp
posted on 1/10/10 at 09:23 AM Reply With Quote
What colour are the wires?
http://jpsc.org.uk/forum/
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 1/10/10 at 04:10 PM Reply With Quote
Good question!
They are red with browny yellow, and red with white.
However, they come from the loom so they could be redundant.
They are on the same spur as the map and the injector wires.
And the builder was away so question still out there!
chris mason
posted on 1/10/10 at 04:13 PM Reply With Quote
possibly the ais valve?
It's not required and there's a good chance you haven't even got it.
Judging on your description and the location of the wires.
[Edited on 1/10/10 by chris mason]
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 1/10/10 at 07:29 PM Reply With Quote
Thanks all.
Ed
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 1/10/10 at 07:45 PM Reply With Quote
RESULT!
Chris, you were right. I fished out a 5VY AIS and the plug on it mated with the plug on the TH/V lead of the loom perfectly. As all the other connections were the correct plugs, it is safe to say the female plug was intended for the AIS!
So all is well! I will sleep a bit better tonight.
Nice one.
Ed
TimC
posted on 1/10/10 at 09:22 PM Reply With Quote
Ed
I thought that's what wine is for?
