Author: Subject: R1 5PW Diaphragm Clutch
Yazza54
posted on 31/10/10 at 07:35 PM Reply With Quote
Hi, I plan on giving my 5PW a full service inc clutch... when changing the plates should I also be changing the diaphragm springs? (or whatever it's called!)
I believe it has doubled up diaphragms, are these a service item or just the plates?
yorkshire-engines
posted on 31/10/10 at 09:12 PM Reply With Quote
These diaphragm plates are not replaced at service and should last the life of the engine
hobbsy
posted on 31/10/10 at 10:28 PM Reply With Quote
Is that Ian's old car?
Are you having any issues with the clutch as unless you are planning a really long trip I wouldn't bother pre-emptively changing the clutch.
I started to get a little bit of slip with just the bog standard clutch - measured the plates and they were fine. Dropped a Barnett conversion on and its been fine since.
I tried the doubled up diaphragms but I didn't like the feel
Yazza54
posted on 31/10/10 at 11:47 PM Reply With Quote
Was Ians yep.. well the clutch doesn't bite til i've let my foot a fair way up. Not sure if thats normal on a bike engine.
Thought it made sense to do it while I was doing the rest?
I'm unhappy cos I eat and I eat cos I'm unhappy
hobbsy
posted on 1/11/10 at 07:40 AM Reply With Quote
That's probably just adjustment, to be honest you don't want the bite point too low else you may have trouble pulling off cleanly?
