Author: Subject: zzr1100 carb question.
jossey
posted on 2/11/10 at 10:45 AM Reply With Quote
ive been offered some carbs for my zzr1100 engine which are the same as mine and have been freshly dyno jetted and balanced and working fine on the donor bike.
if i bought them and put them on my car should they run ok?
or will it need balancing again?
they are exactly the same mopdel carbs.....
cheers
dave
[Edited on 2/11/10 by jossey]
r1_pete
posted on 2/11/10 at 10:48 AM Reply With Quote
As no two engines breath exactly the same they will need re-balancing, but, shouldn't be too far off.
jossey
posted on 2/11/10 at 10:53 AM Reply With Quote
cheers pete.
ill just get mine balanced then i guess.
just need a balancing kit now :O)
cheers
dave
r1_pete
posted on 2/11/10 at 11:17 AM Reply With Quote
I've got a set if you fancy a whizz over to Sheffield, near M1 J31
jossey
posted on 2/11/10 at 11:53 AM Reply With Quote
a loan would be great if you dont mind.
:O)
cheers
im heading up past you tommorow about 3pm ish. if any use?
cheers
dave
