Author: Subject: Kawasaki ZZR1100 -ZX12 water pump interchagability?
craigsimon77
posted on 9/11/10 at 12:41 AM Reply With Quote
Hi All,
I am in the process of making my zzr1100 engine dry sumped. I was going to use Dailey engineering pump that replaces the water pump, but they only make for the ZX12. Does anyone know if they are interchangeable (water pumps). Or is there and existing company that makes one for the ZZR1100 enginine?
cheers
Craig
[Edited on 9/11/10 by craigsimon77]
daviep
posted on 9/11/10 at 05:51 AM Reply With Quote
Pretty sure it's different but you can check part numbers HERE. You can only open one parts list at a time which is a bit annoying.
Regards
Davie
minitici
posted on 9/11/10 at 08:42 AM Reply With Quote
You could always use a Muzzy's dry sump on the ZZR1100, it uses the standard ZZR1100's oil pump and retains the original water pump.
Muzzy's
craigsimon77
posted on 9/11/10 at 09:46 AM Reply With Quote
Thank you that appears to be a good solution.
Craig
daviep
posted on 9/11/10 at 12:17 PM Reply With Quote
I would love a muzzy's
craigsimon77
posted on 9/11/10 at 08:49 PM Reply With Quote
got in contact unfortunately they no longer make the zzr1100 part
