big_l
| posted on 25/11/10 at 08:15 AM |
R1 carb tuning question
Wich screw is for bottom (below) 4000 rpm my car is defo not as it should be it almost sounds like is missing !!! Maybe to lean ?
[Edited on 25/11/10 by big_l]
Check out my blog mnrvortxhayabusa@blogspot.com
RazMan
| posted on 25/11/10 at 09:00 AM |
AFAIK there is no 'screw' for adjusting as you describe - just the idle mixture adjustment
This might give you an idea of how the jets cover the throttle opening
Pilot jet & screw- 0-25%
Needle - 20%-75%
Main Jet - 70%-100%
Have you checked the AFR on a dyno yet?
Raz
big_l
| posted on 25/11/10 at 09:05 AM |
No not checked afr yet only got it on the road yesterday lol
Going to ring daytuner and get it booked in asap just wonderd if there was a way I could get it a little better for now ?
RazMan
| posted on 25/11/10 at 09:10 AM |
A lot will depend on the air filter. If you are running without an airbox then they tend to run quite lean so maybe this is your problem. Either way I
would try and resist the temptation to use it too much until you get it tuned properly - anything at this stage is just guesswork and could end up
very expensive
Raz
