Poll: Westfield - What should I do?? [View Results]
Sell it as it is?
Finish it and sell it?
Finish and compete in it?
Author: Subject: Westfield - What should I do??
lsdweb
posted on 16/12/10 at 05:13 PM Reply With Quote
Time and space are short so what should I do?
[Edited on 16/12/10 by lsdweb]
Westfield
Westfield
franky
posted on 16/12/10 at 05:27 PM Reply With Quote
I guess it depends on what is is!? Is it on the road/new build/what bits are you missing etc etc?
lsdweb
posted on 16/12/10 at 05:41 PM Reply With Quote
Pure racer. Parts wise it's prop, drive shaftes (I've got the inner and outer joints), exhaust manifold (all custom), big sheet of aluminium, a few hundred rivets, seat and odds and sods.
Time wise it needs powder coating and building. The bodywork needs painting too. It's never going to be roadgoing so that makes it a wee bit easier.
prawnabie
posted on 16/12/10 at 05:46 PM Reply With Quote
Id finish it but find out if petty struts are still allowed.
lsdweb
posted on 16/12/10 at 05:56 PM Reply With Quote
The petty strut is removable so hopefully shouldn't be a problem!
posted on 16/12/10 at 06:28 PM Reply With Quote
There's still loads of work to do on it but if you're short of time and space, I'd suggest you sell it.
Phil
Johneturbo
posted on 16/12/10 at 07:14 PM Reply With Quote
scootz will buy it!
Is it a case of short on time, space and money or just the first two?
Could you pay someone to progress it for you in their own premises (also covers the space issue for a while)?
blakep82
posted on 16/12/10 at 07:27 PM Reply With Quote
take the front and back suspension off, put it on its side to save space, and wait for the time
then finish it and compete
________________________
Werner Van Loock
posted on 16/12/10 at 09:25 PM Reply With Quote
if it's not for the money, i'd remove the engine and wheels and hang it from the ceiling up-side down and take it off again when you have the time and space.
If you know it will be a very long time before you start again, best to sell off the tyres and engine. (tyres because they will be useless when they're old and engine as it probably is seized by the time you need it)
http://www.clubstylus.be
hughpinder
posted on 17/12/10 at 09:09 AM Reply With Quote
If its not going on the road I wouldnt waste time stripping and sending for powder coating - slap on some POR15 or epoxy type paint.
That may speed things along a little.
Regards
Hugh
lsdweb
posted on 17/12/10 at 09:30 AM Reply With Quote
Thanks guys - I was thinking about alternative finishes for the chassis as I'm not a fan of powder coating on competition cars - can hide cracks and makes repairs and alterations harder. Trouble is I'm crap at painting!
Wyn
posted on 17/12/10 at 10:40 AM Reply With Quote
eh? the chassis doesn't need to look like the Mona Lisa. It is purely functional so it really doesn't matter how it looks, obvioulsy it makes everyone happier if there are no brush hairs or brush strokes but in the end, even if there are, it isn't going to matter.
A small foam roller fixes both of those problems, I won't believe you if you say you cannot use one of those, a bit of practise and by the time you have finished, the paint finish will be indistinguishable from a professionaly sprayed chassis (by a semi sighted bat of course)
lsdweb
posted on 18/12/10 at 01:15 PM Reply With Quote
Thanks 02GF74
I'll probably give it a go! The steering column bracket needs redoing but it should then be ready for cleaning up and painting.
W
