Author: Subject: sanity check with oil cooler fittings
Johneturbo
posted on 25/1/11 at 07:21 PM Reply With Quote
Having never run a front mount oil cooler before, i'm finding all the options a bit confusing!
could you go over the bits i've listed are they all ok with size and so on
sandwich plate would be thermostatic
this one with 1/2 bsp and a M20 1.5 extension bolt
so unions
thinking these as they are push fit
x2 for the oil cooler end
and 2 x for the sandwich plate end
with this hose
BLUE AEROQUIP PUSH ON HOSE -8 (1/2)
have i missed anything apart from the oil cooler i guess i'd just need a 13row with 1/2 male fittings?
this is for a ZZR14
clairetoo
posted on 25/1/11 at 07:33 PM Reply With Quote
The only problem I can see , is with using those fittings at the sandwich plate would mean you cant remove the hoses at the engine end when pulling the motor out ...............
I use similar fittings to your first picture for both ends , then I can easily dis-connect the hose either end (just need to add a couple of 1/2 BSP adapters)
Its cuz I is blond , innit
Claire xx
Will weld for food......
Johneturbo
posted on 25/1/11 at 07:45 PM Reply With Quote
So claire you mean 2 of these at the sandwich plate end with a male/female bsp fitting for the sandwich plate
[Edited on 25/1/11 by Johneturbo]
clairetoo
posted on 25/1/11 at 07:53 PM Reply With Quote
Yep - that should do it
Claire xx
Johneturbo
posted on 25/1/11 at 09:20 PM Reply With Quote
good job your here
