Author: Subject: first time starting hayabusa
noc231073
posted on 1/2/11 at 01:32 PM Reply With Quote
just ready to start the hayabusa for the first time
one question ....i have removed the spark plug and turned the engine over to bring up the oil pressure...but i still dont seem to have oil coming to the cooler.....
how do i know when i have decent oil pressure if iam using the standard clocks????
omega0684
posted on 1/2/11 at 02:11 PM Reply With Quote
surely when you start the engine the oil pump will engage, do you not have a gauge that tells you the oil pressure or at least a warning light to tell you that you havent?
posted on 1/2/11 at 02:51 PM Reply With Quote
Is the cooler circuit not on a thermostat?
blakep82
posted on 1/2/11 at 02:59 PM Reply With Quote
i'd have thought so too, it may start to fill when it warms up, but would be better filling the thermostat before starting i'd think
don't you have a low pressure warning light on the clocks?
________________________
noc231073
posted on 1/2/11 at 05:47 PM Reply With Quote
Got her started , took a bit of turning over to get the pressures up
