mark chandler
| posted on 6/3/11 at 07:16 PM |
Adding an oil cooler to my blade engined car
On track days the poor old thing tends to get overly hot, also the oil is very black since I added a turbo so time for an oil cooler.
The blade engine has a small little oil filter but these are not dissimilar to many modern cars so I took a gamble and purchased a complete oil cooler
kit off ebay for an escort, second hand got me a sandwich plate, two hoses and A 13 row oil cooler.
On the engine block you have a water cooler that I have discarded, then with a little welding I was able to modify the sandwich plates bolt to fit:
  Oil cooler components
I cut the metric threads off the blade mounting bolt and welded to the sandwich plates bolt.
  Thread adaptor
I then popped down to halfords and had a shuffle through the filter range and found a champion C138 was a nice small filter with 5/8” UNF threads,
just the job.
This also had the advantage that the sandwich plate and filter are shorter than the standard blade setup, I have always struggled to remove my filter
due to lack of space in the car
  Height comparison
It all bolts up nicely, the kit had right angle bends on the cooler hoses so I had to cut and weld straight, this also pushed things out a bit from
the block so a bonus as no clearance issues
  In situ with pipes
Last thing left was to mount to oil cooler and plumb in:
  Oil cooler in place
This works on my car as the rad is behind the front wheels, so longer hoses woukd be required if you wanted to mount out front as is more usual.
Hoping my over heating issues are now sorted, roll on then next local track day
Regards Mark
CRAIGR
| posted on 6/3/11 at 07:25 PM |
Looking good Mark
40inches
| posted on 6/3/11 at 09:25 PM |
You might want to consider fitting an oil stat to stop the oil over cooling
