ettore bugatti
| posted on 8/3/11 at 09:55 PM |
Belt drive conversion
Im currently involved in a Yamaha R1 conversion into a Mini, it is a front wheeldrive setup.
The idea is to use a belt drive instead of a chain.
Now, I have found that it would be possible (in theory at least).
So where could I find pullies that gives me a ratio of about 2.7, that takes the same place as 14/38 tooth sprockets for a chain drive.
I would like to use a pitch of 14mm.
I recon that a 1.5" belt would be wide enough, or should we go wider?
Thanks!
[Edited on 8/3/11 by ettore bugatti]
matt_gsxr
| posted on 8/3/11 at 10:08 PM |
What about the kind of kit they use on massive superchargers. I mean proper dragster blowers, some of those draw big power.
http://theblowershop.com/category/23
designer
| posted on 8/3/11 at 10:15 PM |
American bikers use wide belts, search in the US.
tegwin
Soemthing like this would work...
http://www.bearingboys.co.uk/14M_Taperlock_Timing_Pulley-1808-c
But why would you want to? They can be noisier, ideally need a tensioner on them to compensate for heat stretch....
www.verticalhorizonsmedia.tv
hillbillyracer
| posted on 8/3/11 at 11:26 PM |
I'd be looking for people who deal power transmission systems for industry, there is a massive range of stuff available to transmit the drive
from electric motors etc to where it needs to be on a machine.
I know for example there's an agricultural grass mower called a Kidd Clipper that uses to two toothed belts to drive two 1.2m cutting drums, not
unlike a car timing belt but mabye 100mm wide!
| posted on 9/3/11 at 09:18 AM |
And can snap without warning if you get a stone caught in the pulleys, and availability of spares will be very poor compared to a chain and sprockets.
The lower maintenance (whilst still in one piece!) is really the only thing going for them.
coyoteboy
| posted on 9/3/11 at 11:19 AM |
Chains are remarkable devices when you come to look at it.
ettore bugatti
| posted on 9/3/11 at 01:47 PM |
Thanks for your inputs!
The goal is to be different, however the following advantages are interesting:
-Belts have a constant power lose during their life span. whereas a chain take more power as miles are piled on
-Belt drive system is lighter
-Belts last longer than chain
-Belts don't need lube
-Belts are positive drives and don't have annoying chain snatch
Anyone experience with Gates Poly Chain GT2?
tegwin
| posted on 9/3/11 at 03:50 PM |
No chain snatch?!?? You get elastic retardation instead from the belt...
Lighter?!?!? Unless you get bespoke alloy pulleys I suspect you will end up with stonking heavy steel pulleys.... much heavier than their
"sprocket" equivalant.
Not trying to ruin your fun, good to see something different...
T66
| posted on 9/3/11 at 05:51 PM |
How short are you planning on the belt being ?
A V8 with a top mounted blower still has a decent run of belt between centres, in a fwd engined Mini surely the belt will have to be tiny?
| posted on 9/3/11 at 06:05 PM |
Under ideal conditions, maybe
