tony.g
| posted on 15/3/11 at 10:33 PM |
919 blade oil pressure switch thread size
I need to fit an oil pressure guage 0n my 919 blade engine, which means fitting a t piece where the switch is now.
Does anyone know the thread size?
Andy B
| posted on 15/3/11 at 10:43 PM |
The thread is M10 x 1.5 but it might be easier to remove the boss that it screws into and retap it 1/8 npt as most of the aftermarket senders use
this. The boss can be removed from the main oil gallery using a 17mm socket but it is real tight usually. Be creful when refitting the boss as it is
M2o fine and easily cross theaded.
regards
tony.g
| posted on 18/3/11 at 10:45 PM |
Thanks for the help and advice Andy.
tony.g
| posted on 19/3/11 at 10:50 PM |
Are you sure it's 1.5 and not 1.0.
Sorry to doubt you but i have been looking for adapters and can't find any in 1.5.
