Author: Subject: Fitting new clutch(fireblade 954)
Gordy
posted on 27/3/11 at 06:53 PM Reply With Quote
Out today for run when clutch started slipping when accelerating through higher gears, so reckon its time for a new clutch. Any tips/advice on fitting new one myself?, need to purchase new clutch (honda oem) and barnett springs, anything else? Thanks Gordy.
posted on 27/3/11 at 07:16 PM Reply With Quote
Check the thickness of the steels and the friction plates and see if they are within tolerance. It could be that you only need the Barnett springs (Unless you've already fitted them)
Phil
Gordy
posted on 27/3/11 at 07:50 PM Reply With Quote
Already got barnett springs, so must be clutch?
posted on 27/3/11 at 08:25 PM Reply With Quote
Yep, sounds like new clutch. You might also need a new gasket for the clutch cover. If you can tilt the engine before removing and fitting the new clutch, you may not need to drain any oil. Other than that, sounds like you've got it covered. Definitely go for OEM frictions and plates.
Phil
Gordy
posted on 27/3/11 at 08:38 PM Reply With Quote
Thanks Phil.
mad-butcher
posted on 28/3/11 at 05:37 PM Reply With Quote
Make sure it's properly adjusted, and then tell your left boot it's a bike clutch and "she'll be right mate." I wear baseball boots or an old pair of 3mm neoprene diving boots.
tony
Gordy
posted on 28/3/11 at 06:04 PM Reply With Quote
Clutch was in car when i bought it Tony, have had car 3 years now, done nearly 4000 miles and half a dozen trackdays and never experienced clutch slipping before, tbh i'm always gentle on clutch and use minimal revs when pulling away, so i'll replace clutch just to be safe, with the long summer ahead
mad-butcher
posted on 28/3/11 at 07:10 PM Reply With Quote
Appologies thought you'd just bought it and were new to the sensativity of bike clutches,
tony
[Edited on 28/3/11 by mad-butcher]
