YQUSTA
| posted on 22/5/11 at 10:23 PM |
1998 Blade rev bouncing at 3k (Part 2)
Following on from this thread we have tried all the ideas but to no
avail.
When we took the jets out we did find some crud in 1 and cleaned all the jets ect with carb cleaner and all looked nice and clean afterwards.
Anyone with any other ideas they would be very welcome.
Edit: also took the tps off and checked it we got resistance change so guess this is OK.
[Edited on 22/5/11 by YQUSTA]
"If in doubt flat out"
Colin McRae
r1_pete
| posted on 23/5/11 at 08:54 AM |
What did you replace wrt the pickup and ECU? where you say there was some sign of arcing?
ReMan
| posted on 23/5/11 at 09:09 AM |
Can I suggest you check regulator connectors and also charging voltage
YQUSTA
| posted on 23/5/11 at 04:47 PM |
r1_pete: there was a wire that was for the pick up which appeared to have arching at the connector to the ecu so I replaced the wire and ECU.
Took out the plugs today and found what looks like oil around the thread and shoulder, also the plugs were sooty and black.
Did a quick compression test with closed throttle and got 100-105 psi on all 4 cylinders.
cleaned the plugs and tested.
The engine was better but the revs now stutter at 2k but not the bouncing at 3k like before. Only ran it for1 min then removed a plug and the oil had
returned.
not sure were the oil is comming from but see no obvious signs.
ReMan: do you know what the charging voltage should be?
Thanks for all the ideas
Colin McRae
mistergrumpy
| posted on 23/5/11 at 06:12 PM |
Forgive me if I'm teaching you to suck eggs but have you tried balancing the carbs now? It's just that after a winter sitting mine
developed a stutter at 1500-2000rpm and I've just sorted it I think by balancing. Hope it helps.
ReMan
| posted on 23/5/11 at 08:41 PM |
Approx 14.4V
www.plusnine.co.uk
YQUSTA
| posted on 23/5/11 at 09:23 PM |
mistergrumpy: Yes I have balanced the carbs only 1 was a little out made no difference.
Thanks ReMan I will check the charging voltage.
Colin McRae
