Author: Subject: 5VY overide neutral only start
swalf3
posted on 7/6/11 at 06:14 PM Reply With Quote
Any advice please to get 5VY R1 to start in any gear position?
Thank you.
swalf3
StevieB
posted on 7/6/11 at 06:40 PM Reply With Quote
Should be as straight forward as finding the side stand switch and join the two wires together.
swalf3
posted on 7/6/11 at 06:59 PM Reply With Quote
Steve,Thank you.I'll try that.
swalf3
Johneturbo
posted on 7/6/11 at 10:15 PM Reply With Quote
To start in gear you will also need to find the clutch switch and make the circuit
ETA blue/yellow and black/yellow are the clutch switch wires, join them together for any gear starting...but don't leave it in gear when you turn it over
[Edited on 7/6/11 by Johneturbo]
eddie99
posted on 7/6/11 at 10:19 PM Reply With Quote
You'll need to find the clutch switch, and possibly put that to a momentary switch. If you just connect it up, then some modern bike engines cut second injectors and do all kinds of funny things. I have a small momentary switch on the steering wheel.
[Edited on 7/6/11 by eddie99]
Johneturbo
posted on 7/6/11 at 10:24 PM Reply With Quote
Nope you just need to join them together on the 5VY
swalf3
posted on 10/6/11 at 10:42 AM Reply With Quote
Thank you everyone for the solution.
All the best.
swalf3
