SteveSEIW2000S
posted on 9/6/11 at 09:58 AM |
Duratec Clutch Help
OK, so my problem is that I came to bleed the clutch at the weekend and when all complete I pressed the clutch to check the pressure and found that
the pushrod into the master cylinder became only what can be described as loose.
I have since taken the master cyliner off and it appears to be working as it should directly after loosing off the clutch pipe banjo.
I have the following parts fitted in my clutch :
Fiesta ST Flywheel (Solid)
Pinto uprated clutch plate
Fiesta ST pressure plate
Mondeo type Slave Cyliner
Raceline Bellhousing
Mitchell Cotts Gearbox.
The issue is, to find out whether the slave has stuck in the pressure plate fingers means an engine out job. Anyone out there experienced a similar
issue or can advise before I take the plunge and take the lot out again?
big-vee-twin
posted on 9/6/11 at 11:20 AM |
I used a RS Turbo pressure plate and like yours is from a FWD car.
In order to ensure that I didnt have your problem I have shortened the clutch fingers by about 3mm as the central hole reduces in diameter when the
clutch is pressed and as you say the fingers can bind on the guide tube.
Flak Monkey on here also did the same thing.
Another thing to consider is; are the fingers on the pressure plate flat if they are, you will need a rounded face thrust bearing such as the one from
a SAAB this allows the bearing and fingers to roll around each other.
http://www.triangleltd.com
austin man
posted on 9/6/11 at 02:21 PM |
Brother in law is using the zetec cylinder on his silvertop utilising zetec clutch and pressure plate and flywheel onto a type nine box. He did buy a
kit with a spacer to move the release bearing closer to the pressure plate. Unfortunately it was designed with the Pinto plate in mind so the throw
was incorrect resulting in a knackered hydraulic bearing. He has sine had another spacer made to his requirements and all is now good.
You dont mention whether you are using the spacer if not potentially expensive problem ahead. His did last for around 5o miles before losing all its
fluid
SteveSEIW2000S
posted on 9/6/11 at 03:37 PM |
fluid
The raceline bellhousing has a direct mount for the slave cylinder therefore I dont believe a spacer is required ??
austin man
posted on 9/6/11 at 03:46 PM |
the spacer the brother in law had was possibly 3 inches high he bought the kit from a retro ford place if that helps any
big-vee-twin
posted on 9/6/11 at 09:33 PM |
I have the same bell housing and have a spacer in behind the cylinder, the cylinder does mount directly but you need to mount the bell on the engine
and measure the distance to the fingers from the back of the bell deduct the length of the cylinder which leaves you with a spacer depth mine I think
was 12mm.
You may also need to trim the fingers as I did
SteveSEIW2000S
posted on 10/6/11 at 08:36 AM |
was 12mm.
Did you use a solid flywheel also ? and who supplied the spacer for your assembly ?
