Author: Subject: R1 airbox noise levels
sdh2903
posted on 21/6/11 at 06:50 PM Reply With Quote
Hi all
Im using a 99 4xv R1 lump and I have both the standard airbox and a pipercross sausage filter. I had planned to use the std airbox however its going to need a very large scoop to house it. If I use the pipercross it means that I can use a more normal scoop. Am I going to struggle with noise levels for IVA with a sausage filter?
I will be using the std R1 can btw.
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 21/6/11 at 07:05 PM Reply With Quote
If you already have a bonnet scoop you can turn the airbox through 180 degrees with a few mods and possibly cut the top down and it will reduce the height.
[Edited on 21/6/11 by CRAIGR]
sdh2903
posted on 21/6/11 at 07:15 PM Reply With Quote
Already done that and its still a bit high!!
danny keenan
posted on 22/6/11 at 12:14 PM Reply With Quote
a pipercross filter on an r1 is not that noisey.its alot less than a suzuki.
thanks danny
johnny chimpo
posted on 22/6/11 at 12:45 PM Reply With Quote
what about the pipercross 600 series airbox?
