blueskate
| posted on 1/8/11 at 08:08 PM |
r1 5pw intermittant high ideal speed
Hi all,
My indy has developed a bizarre idle problem. basically when it has warmed up i pull up at a junction it will idle at around 2000 rpm. if i leave it
eventuslly it settles. Sometimes however it behaves itself? The throttle doesn't appear to be sticking. If I engage a gear I can bring the idle
speed down with the clutch sometimes it stays down but sometimes it goes back up 2KrPM
Any ideas?
BTW I am running a power commander if that makes any difference?
TIA
Semper Paratus!
Bigboystoys
| posted on 1/8/11 at 10:23 PM |
The choke on the 5pw is managed by the water temp and coolant system, it may have some trapped air in the choke housing or a small split in the pipe
that feeds it. I would start with the choke if you have never had issues before then go from there.
