Author: Subject: 919 blade advice
tony.g
posted on 15/9/11 at 09:59 PM Reply With Quote
919 blade advice
I have got to strip and rebuild the gearbox on my 919 blade.
Is it a total engine strip or can you just strip the bottom end and split the crank case?
Benzo
posted on 16/9/11 at 01:04 AM Reply With Quote
you can split the crank case.. i am doing mine at the minute swapping a box over into another engine.
ReMan
posted on 16/9/11 at 10:55 AM Reply With Quote
You "just" split the crankcase.
Only the selectors can be removed (fiddly) without
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
