aka Keith
| posted on 19/11/11 at 01:43 PM |
prop adaptor removal? or issues
My car starting making a random clunking noise, and now having taken the engine out of the car, is looks as if there is slight movement in the prop
adaptor (from side to side) - only about 1 mm but at BEC revs this I would have thought is a no no?
So apologies for the dumb questions, but as I did not put the car together, how do I remove the adaptor? looks like it has a washer or a piece of
metal bent at the base to stop it from working loose.
Picture is in my archieve - as I still have not managed to work out how to upload to the forum.
Craig
owelly
| posted on 19/11/11 at 01:51 PM |
That is the tab washer that you cam see bent up onto the fkat of the nut. Tap the tab back and undo the nut.
http://www.ppcmag.co.uk
tomgregory2000
| posted on 19/11/11 at 02:05 PM |
  prop adaptor
here you go
ps the prop wont be going any faster in a bec than a cec (diff ratio being the same, etc) as the prop rotation is in relation to the rotation of the
road wheel
[Edited on 19/11/11 by tomgregory2000]
jase380
| posted on 19/11/11 at 05:46 PM |
As Owelly says, tap the washer flat then remove nut, you will probably need an impact gun to shock it loose rather than trying to get a socket on it
and stop the shaft rotating at the same time
Johneturbo
| posted on 19/11/11 at 06:21 PM |
road wheel
+1 with that, i even had the guys at DF telling me that probs wear out faster on BEC because of the high rpm
[Edited on 19/11/11 by Johneturbo]
aka Keith
| posted on 20/11/11 at 01:10 PM |
Cheers folks,
I took the adaptor off this morning and could find no play in the actual output shaft. so I popped the adaptor back on and tightened it up nice and
tight and bingo - no more movement - it would appear that the sprocked adator nut had beome a fraction loose - is this common?
Or am I clutching at straws and just not wanting to break the engine down.
Craig
tomgregory2000
| posted on 20/11/11 at 10:00 PM |
i believe that it is a common problem with bec that the prop adaptor securing nut comes loose and then the prop falls off and removes whatever it
comes into contact with
