Author: Subject: reg/ rect relocation
andyfiggy2002
Builder
Posts 236
Registered 10/6/05
Member Is Offline
Photo Archive Go!
Building: built megablade in 2004 & ive still got it
posted on 1/1/12 at 01:22 PM Reply With Quote
on the bike the regulator/ rectifier is open to lovely cooling air but on my 893cc blade its shielded under the scuttle. If i were to relocate it to the front of the car this would mean splicing in extension wires. In its current set up the original connector from the alternator is often prone to burning themselves out so is this new way going to work considering im adding even more connectors?
snapper
posted on 1/1/12 at 01:33 PM Reply With Quote
Ally heat sink and fan may help like you get on powerful computer processors.
I eat to survive
I drink to forget
SPYDER
posted on 1/1/12 at 03:14 PM Reply With Quote
Like Snapper has suggested, just add on a small cooling fan. We have done this on our 929 engined Phoenix to good effect.
rgrs
posted on 1/1/12 at 09:52 PM Reply With Quote
Thermal heat compound and bolt it to the passenger bulkhead, it keeps the wiring lengths to a minimum and does not need a fan.
If you need more power try the superdream reg/rectifier unit it's a bit more robust.
Roger
andyfiggy2002
Builder
Posts 236
Registered 10/6/05
Member Is Offline
Photo Archive Go!
posted on 1/1/12 at 10:38 PM Reply With Quote
from the replies i assume its not a good idea to lengthen & add more blocks then? a simple yes or no is all i'm after
[Edited on 1/1/12 by andyfiggy2002]
rgrs
posted on 2/1/12 at 06:08 PM Reply With Quote
No do not add any further connectors, you can however extend the existing wiring using cable of the same or larger size (csa) and solder/sleeve connections without any issues.
As you already know the oem connectors have a habit of melting, The original regulator is fine for charging batterys up to abot 18 Ah, anything more and it's probably a bit underated.
Roger
