Murphy
| posted on 15/1/12 at 08:52 PM |
Oil temp R1
I have an oil temp gauge with sender and T peice. Where on the R1 1999/2000 model do I put this? Also with the water temp gauge where do I put the
sender bits?
Sorry I have very little know how here.
Cheers all.
sdh2903
| posted on 15/1/12 at 09:17 PM |
On that engine you've really only got a couple of options for an accurate oil temp reading, you can either tap into the sump or use a sandwich
plate on the filter. I ended up using a sandwich plate with a small filter which had tap offs for oil temp and pressure as in pic below:
  sandwich plate
For the water temp I used an inline adapter you can just see above the carbs
  eng
Murphy
| posted on 15/1/12 at 09:24 PM |
I was thinking sump but the plate idea is really good. Would this be an eBay job.
Murphy
| posted on 15/1/12 at 09:37 PM |
sdh2903
| posted on 15/1/12 at 09:39 PM |
Yeah it was one of these:
Oil Sandwich Plate Universal Fit gauge sender silver | eBay
I did have to file a fair bit off around the circumference to get it to fit.
Murphy
| posted on 15/1/12 at 10:07 PM |
Awsome info mate, brilliant thanks.
Murphy
| posted on 16/1/12 at 09:53 PM |
Another question
I have an oil temp gauge to put on but what other gauge on oil is most important?
[Edited on 16/1/12 by Murphy]
sdh2903
| posted on 19/1/12 at 06:38 PM |
The other take off is for oil pressure, I would say along with water temp the most important gauges to have.
Murphy
| posted on 29/1/12 at 02:17 PM |
One more question
On the sandwich plate I had to file off so much I only have the inner rub er seal between he plate. Will that be OK.
sdh2903
| posted on 29/1/12 at 03:45 PM |
Mine was the same, I,ve had it running for an hour or so with no issues. I cant see it being an issue as long as the 1 seal is in good shape.
Murphy
| posted on 29/1/12 at 08:01 PM |
Fitted it today and ran it for 1/2 hour no issues.
Game on! Just need some good weather.
