andyfiggy2002
| posted on 18/2/12 at 03:34 PM |
carbon R1 can
ive heard that this can can reduce exhaust noise which has been the one of my main prohibiters apart from induction noise to me doing trackdays
1. how effective would this be on my 893cc megablade at reducing noise?
2. do they sap power?
3. why are they so different to my straight through westfield can?
4. what year R1 can am i looking for?
5. is it just the carbon one thats the most effective?
6. if theres an alternative what are you other guys using?
YQUSTA
| posted on 18/2/12 at 04:16 PM |
I have one of these not cheap I know but it really made a big
difference to my ZX9r engined MK, I think from memory it reduced the noise by around 5-7 db and that was from an R1 carbon can, tested with the same
noise meter from the same distance.
I had no scoop and the filter open to the air at the time so alot of induction noise also.
"If in doubt flat out"
Colin McRae
daniel mason
| posted on 18/2/12 at 04:42 PM |
try mnr. they have some large lightweight silencers which provide excellent db levels for track use
big_l
| posted on 18/2/12 at 06:02 PM |
I'll second that mr mason try there really nice can as well
Check out my blog mnrvortxhayabusa@blogspot.com
ReMan
| posted on 18/2/12 at 06:06 PM |
Like this one on my 893
  tryagain1
98dB with std airbox and power is still good
plus you can get them unmodified for about £50
and they still sound nice, but barley notice the power drop over my straight thru Viper
www.plusnine.co.uk
andyfiggy2002
| posted on 18/2/12 at 10:18 PM |
yeh reman, thats what im on about, i guess its just the cans inlet pipe that needs modifying to match my existing header outlet pipe & the cans
outlet pipe extending so it dont burn the rear wheel arch.
I read that your 98db was at 7k or 2/3 max revs with the bike airbox, mine at same revs was 103db but with a more open sock filter so i guess i have
an induction noise issue to, something tells me that i gotta un-dynojet & get bike box like you
is it worth it i ask myself when so many tracks now specify nearly full revs at 3/4!!!!
[Edited on 18/2/12 by andyfiggy2002]
ReMan
| posted on 18/2/12 at 10:57 PM |
you;ll probly find with a decent (kandn) filter in a box you dont need to change the jts, it wont hurt running a tad rich if it does
There used to be a guy on the bay selling these ready modified at both ends for about £100
www.plusnine.co.uk
andyfiggy2002
| posted on 18/2/12 at 11:08 PM |
i have 132 jets compared to your set up which if its the same as the standard bike will be 115,s so mine will be way to rich if i stick the bike box
on
i to remember the guy on ebay selling already modified R1 cans for BEC's but it seems he is no more, by the way what year was yours, 98 per
chance? & how easy was it to get it re-welded?
Andy W
| posted on 18/2/12 at 11:35 PM |
I've modified a number of these cans (some pictures of the parts I've made in myarchive)
problems with most of the later ones is they are titanium and you can't weld any of the stainless parts to them.
I really stopped doing them as the doner cans are getting rarer.
andyfiggy2002
| posted on 19/2/12 at 12:49 AM |
ok as your the man in the know, why are these cans quieter?
Bigboystoys
| posted on 19/2/12 at 08:57 AM |
My understanding is that standard bike cans pass the gasses round several different chambers inside the end can therefore dampening the volume as the
gasses travel further and further until the finally exit the end of the can. I had the same trouble as this last year with my gsxr powered car. In the
end I went to see Paul gooderham (907) on here who made me up a beautiful can from scratch for an excellent price. Cheers Sam
big_l
| posted on 19/2/12 at 09:16 AM |
I'm going to run a pipercross p600 air box do I can duct air in from
The front of the car !!!
andyfiggy2002
| posted on 19/2/12 at 09:38 AM |
thanks guys. i guessed it was different chambers, so bigboystoys what db are you getting at 3/4 revs & how much was the exhaust ?
as my current westfield straight through exhaust comes apart easily i wonder if i modified it by inserting some partitions with the perforated tube
cut into say 3 pieces & staggered, just a thought
big_ l, as regards ducting to fit over pipercross i could only find the reverie ones which were at a silly price
Bigboystoys
| posted on 19/2/12 at 10:23 AM |
I chose not to have mine measured although Paul did offer. Mine was just perfect for me on the road and motorways no longer make my ears bleed. I
payed £250 fully fabricated and fitted with a one off mounting bracket. The detail and finish on the can is perfect. Lots of people on this forum have
cans made by him
andyfiggy2002
| posted on 19/2/12 at 04:51 PM |
i assume this is the 600 series airbox your talking about? can anyone thats used one recommend them for getting the noise down?
http://www.demon-tweeks.co.uk/Product.do?method=view&n=1691&p=246392&utm_source=Google&utm_medium=Base&utm_campaign=Universal
%20Air%20Boxes
[Edited on 19/2/12 by andyfiggy2002]
bigfoot4616
| posted on 19/2/12 at 06:34 PM |
it'll quieten it a bit but i wouldn't recomend it. mine fell in bits in less than 2 years and is now patched up with fibreglass. wont be
using it on the r1 engine
rolling road also showed the filter to be very restrictive.
ReMan
| posted on 20/2/12 at 07:53 PM |
Could you not fit a std airbox under your bulge?
www.plusnine.co.uk
