PAUL FISHER
posted on 25/2/12 at 04:45 PM |
Dynojet kit fireblade
Just fitting my dynojet kit this afternoon to my 893 fireblade, all going well, but just got to the last bit fittng the needles, removed the old
needles and on each was a E clip, a seat washer and a half shim washer.
Now in the instructions sent from Andy at AB, it just says remove the seat washer and the E clip, then fit the the old seat washer to the new needle,
but do not fit the half shim washer in the kit, but it does not mention either removing the old half shim washer, or fitting it to the new needle, I
think I should just fit the E clip and seat washer, but just need someone who's done it to confirm, I could ring Andy on monday, but as Ive got
all the carbs in bits on the dining room table, and the house is full of petrol fumes, our lass is getting a bit upset about it .
Andy B
posted on 25/2/12 at 05:55 PM |
Hi Paul
just spotted your thread, you are bang on - fit the e-clip and old seat washer, do not use the smaller half shim, these represent half spacing of the
groove positions to give greater flexibility on set up, however numerous dyno runs suggest that 2nd groove from top and no half shim works best.
Will be at the unit on Sunday if you are uncertain
best regards
PAUL FISHER
posted on 25/2/12 at 08:54 PM |
Thanks Andy, also thanks for the free carb trumpets you sent me with my
Kit, just the job, cheers Paul
Steve Hignett
posted on 26/2/12 at 06:45 AM |
Shocker...
A thread in which Andy Bates does a good job and gets thanked...
